Hi, i have log file in grafana using loki data source the problem is i want to make table in grafana for specific messages in the log . multiple methods of msg in the logs. so i need two coloumn one is msg type or method another coulmn is count of each methods. in the screenshot i need to get count of that msg type how many time it occurs within the hour or minute.
This documentation could help.
Furthermore, rate gives you the occurs in a second, so you have to divide the result.
Maybe this query your solve you problem:
sum by(msg) (rate({}
| json msg="log.msg"
| msg != ``
[$__range]))
And you must select queryType instant.
