I am currently using grafana 8.5.4 and mac os 12.4 -
I am trying to save a custom PromQL query as a template variable which i can use in multiple panel dashboards.
I want to plot a overall health dashboard for my systems. If a value in a panel goes beyond warning threshold but below error threshold then I am plotting it as 1 (or in yellow color) if it goes beyond error threshold then i am plotting as 2(or red color) in another panel.
I have a separate result panel which tracks threshold breach in 3 different panels.
I am planning to use following queries
warning - (vector(1) and on() (25 <metrics_size >0)) or on() vector(0)
error - (vector(2) and on() (metrics_size <0)) or on() vector(0)
I have to create 6 different queries (2 for each panel) for result panel.
Can we store this as template query? where i can just change threshold values and metrics name?
If yes how to achieve that. I really appreciate if you suggest any alternate feasible solution for this problem.
