Sample Datasource for Plotly Panel Plugin
I want to use plotly panel plugin for visualization. Can anyone tell me which different datasources we can use in plotly? If anyone worked on plotly and have some sample data with datasource then it is very helpful.
Thank You.
Mihit
It should support most data sources. If it works with the graph panel then it should work with Plotly too.
I use it with InfluxDB, which works smoothly. All you have to do is select the metrics from DB and attach them to the axes.
I tried with simple JSON Datasource and It’s working. I think it works with all the datasources.
Thanks.
