Following the basic example in the docs (S3Client.putObject(bucketName, objectKey, data))
Produces the following error:
S3ServiceError: There were headers present in the request which were not signed
I’m not sure what I’m doing wrong here. I just replaced the bucket name with one that I own and added my keys in the ENV.
Hi @shane.ontraccr
Welcome to the community forums
Thanks for reporting this issue. So far, from my investigations, it seems something introduced in version 0.7.0
. While we keep digging, the example should work fine with version 0.6.0
. I changed the import and the example worked for me:
import { AWSConfig, S3Client } from 'https://jslib.k6.io/aws/0.6.0/s3.js';
If you are looking for more examples you can also visit the repository: https://github.com/grafana/k6-jslib-aws/blob/main/examples/s3.js
I’ll get back here once we figure out what changed. Again, many thanks for spotting this.
Cheers!
Thanks! It seems to have worked. Is there a way to customize the headers (such as Content-Type or Content-Disposition)?
Hi @shane.ontraccr
Thanks for your patience. I opened the issue Error some headers are not signed with version 0.7.0 · Issue #28 · grafana/k6-jslib-aws · GitHub and proposed a PR to fix this. I’ll discuss this with the maintainer, as this is simply my proposal. You can follow the issue to see how it’s finally resolved.
Looking at the code I think it’s not possible to add headers such as Content-Type
. We are always passing empty headers and the code creates the authentication/signing headers. It looks like a good feature to add, so I went ahead and opened: Support for headers like Content-Disposition or Content-Type with putObject · Issue #30 · grafana/k6-jslib-aws · GitHub.
Many thanks for your contributions
Cheers!
Hi @shane.ontraccr
We published the fix in version 0.7.1. The following import should work now:
import { AWSConfig, S3Client } from 'https://jslib.k6.io/aws/0.7.1/s3.js';
Let us know if you are still hitting issues. And many thanks for reporting this.
Cheers!
