S3 endpoint with simple scalable deployment with Helm
I try to deploy Loki using Helm via simple scalable deployment chart 1.6.1 and Loki 2.5.0 image.
the both read & write pods containers have errors when connecting to the S3 endpoint, here’s my config :
data:
  config.yaml: |
    auth_enabled: true
    common:
      path_prefix: /var/loki
      replication_factor: 3
      storage:
        s3:
          access_key_id: <key_id>
          bucketnames: loki
          endpoint: https://my.s3.endpoint.com
          insecure: false
          region: null
          s3: null
          s3forcepathstyle: false
          secret_access_key: <key_secret>
In logs I can see theses errors :
err=“RequestError: send request failed\ncaused by: Put "https://loki.my.s3.endpoint.com/dev/789eb3fff04dd168/181d40e30aa%3A181d47c42dc%3A1e1826a6\”: dial tcp: lookup loki.my.s3.endpoint.com on 10.111.0.10:53: no such host"
I don’t understand why the endpoint url is generated with the bucketname, that is create an unknown domain.
Thanks
I believe that you need to change your bucketname structure to the following…
bucketNames:
  chunks: chunks
  ruler: ruler
  admin: admin
If I set this bucketname structure in my Helm config, I get the same problem.
The write container tries to join chunks.my.s3.endpoint.com and the read container tries to join ruler.my.s3.endpoint.com
The solution is to set to true the s3forcepathstyle parameter
