I am trying setup Loki in a simple scalable architecture on Kubernetes. My intentions are to have:
- One loki-gateway
- Two loki-read
- One loki-write
- One loki-backend
I am able to run helm and get the pods setup and running as expected. However, when I attempt to write to Loki, I get 503 response from the gateway. I have a feeling my config map or member list is not setup right. This is my first attempt at deploying Loki and its all new to me.
This is the curl command I use to write to Loki:
curl -v -H "Content-Type: application/json" -XPOST -s "http://{kubernetes-cluster-domain}/loki/api/v1/push" --data-raw '{"streams": [{ "stream": { "foo": "bar2" }, "values": [ [ "1570818238000000000", "fizzbuzz" ] ] }]}'
This is what runtime-configmap.yaml looks like:
apiVersion: v1
kind: ConfigMap
metadata:
labels:
helm.sh/chart: loki-5.5.0
app.kubernetes.io/name: loki
app.kubernetes.io/instance: my-loki-loki
app.kubernetes.io/version: "2.8.2"
app.kubernetes.io/managed-by: Helm
data:
runtime-config.yaml: |
service-memberlist.yaml
apiVersion: v1
kind: Service
metadata:
labels:
spec:
type: ClusterIP
clusterIP: None
ports:
- name: tcp
port: 7946
targetPort: http-memberlist
protocol: TCP
publishNotReadyAddresses: true
selector:
app.kubernetes.io/part-of: memberlist
service-gateway.yaml:
apiVersion: v1
kind: Service
metadata:
labels:
app.kubernetes.io/component: gateway
spec:
type: ClusterIP
ports:
- name: http
port: 80
targetPort: http
protocol: TCP
selector:
service-write-headless.yaml
apiVersion: v1
kind: Service
metadata:
labels:
app.kubernetes.io/component: write
prometheus.io/service-monitor: "false"
spec:
type: ClusterIP
clusterIP: None
ports:
- name: http-metrics
port: 3100
targetPort: http-metrics
protocol: TCP
- name: grpc
port: 9095
targetPort: grpc
protocol: TCP
appProtocol: tcp
selector:
service-write.yaml
apiVersion: v1
kind: Service
metadata:
labels:
spec:
type: ClusterIP
ports:
port: 3100
protocol: TCP
- name: grpc
port: 9095
targetPort: grpc
protocol: TCP
selector:
Any help will be greatly appreciated.
