Running K6 through Powershell with xk6 influxdb extension fails
I get this error code when trying to output results to influxDB v2.x via my Powershell script in the same directory as my k6 build.
invalid output type ' xk6-influxdb', available types are: cloud, csv, experimental-prometheus-rw, influxdb, json, statsd, xk6-influxdb
$influx_addr = "http://localhost:8086"
$influx_org = 'my_org'
$influx_bucket = 'my_bucket'
$influx_token = 'my_token'
$influx_info = $env:K6_INFLUXDB_ADDR = $influx_addr; $env:K6_INFLUXDB_ORGANIZATION = $influx_org; $env:K6_INFLUXDB_BUCKET = $influx_bucket; $env:K6_INFLUXDB_TOKEN = $influx_token;
$out = $env:K6_OUT = '-o xk6-influxdb=http://localhost:8086/my_bucket'
$influx_info; .\k6.exe run .\PerformanceTest.js $out
Hi @DuneZerna. When specifying your output using the K6_OUT environment variable, you should not use the -o argument flag.
$out = $env:K6_OUT = ‘-o xk6-influxdb=http://localhost:8086/my_bucket’
should instead be
$out = $env:K6_OUT = ‘xk6-influxdb=http://localhost:8086/my_bucket’
Then, with the environment variable set, you can remove the use of the $out variable from your actual command as in:
P.S. I’m not a Windows user…so I can’t verify any of this.
