Router_logging missing userid and uname
Grafana 8.4.4
Grafana Official Docker Image
See the userid and username in Router Logs
Enabling the router_logging option
  • What happened?
I’m using AzureAD as an Identity Provider and in the previous Grafana version that I was using 7.6, I was able to see the user ids and names in the router Logging
In Grafana 8 I would like to keep seeing the userid and uname in the router logs
Just enabling Azure AD authentication and enabling the router_logging
No errors.
@nicolastakashi did you make an issue for this in the repo? Did it get any traction?
