Grafana-Loki with AzureAD
    Grafana v9.3.2
    NAME=“CentOS Stream”
    VERSION=“8”
    I have the authentication to AzureAD and HTTPS working, however when a user logs in they are just viewing. I need it to have Server Admin (if possible) when authenticated.
    I have configured AzureAD properly in the Enterprise Applications then App Registration. I have all the clientID and Client Secret App ID and such. I have also configured the Grafana.ini Properly as well except mapping the users to where we have admin access.
  • What happened?
    I found the url below to help me with mapping roles (from AzureAD to Grafana) - I am unsure of where I am to put the code if someone could show me an example I can complete this task. Does it go in the Manifest on the AzureAD side or the Grafana.ini Side?
    I don’t know as of yet, I don’t know where to put it.
  "allowedMemberTypes": ["User"],
  "description": "Grafana server admin Users",
  "displayName": "Grafana Server Admin",
  "id": "SOME_UNIQUE_ID",
  "isEnabled": true,
  "lang": null,
  "origin": "Application",
  "value": "GrafanaAdmin"
Also where do I get that unique id from?
    None as of yet.
    Configure AzureAD OAuth2
I apologize if this is a stupid question but I am seriously stumped. Just for the record I am not in as an Admin of sorts. I can only view if you notice all of the icons are not in the navigation panel on the left.
Thanks for your help guys/ladies I appreciate it.
Michael
