I have tried setting up a root path for my grafana instance as suggested in the below URL
http://docs.grafana.org/installation/behind_proxy/
Configration in my defaults.ini is
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana
After restarting the grafana server, I am getting 404 error for the below url.
http://localhost:3001/grafana/
And even for the base URL,
To start with you are changing values in the wrong ini file. Changes should be made in the custom.ini -> http://docs.grafana.org/installation/configuration/#config-file-locations
What value did you set for server.domain?
torkel
4
set root_url to the root url you want to use in your browser, so for example root_url = http://myserver/grafana
Then you need a reverse proxy that does the url translation: (required if you want grafana under subpath)
http://docs.grafana.org/installation/behind_proxy/#nginx-configuration
Thank You for the response, I have moved my custom configurations to cusctom.ini,
[server]
The full public facing url
root_url = http://grafana.staged-by-discourse.com/grafana
This is the complete configuration I have in custom.ini
torkel
6
great, so it’s working now?
