Hello Grafana community, I have recently attempted to reverse-proxy my Grafana instance behind HAProxy. Problem is, when I attempt to load Grafana on the reverse-proxied address it doesn’t work, as in it gives me an error like this:
Logging out and back in doesn’t change anything and I cannot access any of the menus without them showing no content except for an error, the only exception being for the one to log out.
Accessing Grafana via its IP address and standard port (3000) works fine.
Grafana config:
instance_name = example grafana
[server]
domain = grafana.example.dev
[security]
cookie_samesite = strict
[users]
allow_sign_up = false
allow_org_create = false
[auth.anonymous]
enabled = true
hide_version = true
HAProxy config (partially cut out):
maxconn 100000
log 127.0.0.1:514 local0 info
user haproxy
chroot /usr/share/haproxy
pidfile /run/haproxy.pid
daemon
ssl-default-bind-options ssl-min-ver TLSv1.2
frontend website
bind :80
bind :443 ssl crt /etc/ssl/site/merge.pem
mode http
log global
option httplog
option dontlognull
option http_proxy
option forwardfor except 127.0.0.0/8
timeout client 30s
http-request redirect scheme https unless { ssl_fc }
acl api path_beg -i /api /metrics
acl grafana hdr_beg(host) -i grafana
acl pxmx hdr_beg(host) -i proxmox
use_backend api if api
use_backend grafana if grafana
use_backend pxmx if pxmx
default_backend nginx
backend grafana
log global
mode http
balance roundrobin
timeout connect 5s
timeout server 30s
timeout queue 30s
server grafana 192.168.1.143:3000 check
Thanks in advance!
