v8.5.15 -
I am trying to get the CPU percentage on per session during the execution, and update the cpu percenge in low or mederate or high according to the average cpu usage percent . -
I am using case statement to update the cpu percent in any one column like low/moderate/high according to cpu usage percent. -
What happened?
Its getting updated in all three columns like low/moderate and high -
Cpu percent should update in either of the column according to the usage percent -
QUERY: (used case statement )
AVG(CASE WHEN (cpu > 0 and cpu <= 50 ) THEN (cpu) END) AS
low,
AVG(CASE WHEN (cpu > 50 and cpu <= 70 ) THEN (cpu) END) AS
moderate,
AVG(CASE WHEN (cpu > 70 ) THEN (cpu) END) AS high,
Dint received errors but it gets updated in all three column which is not expected. -
Did you follow any online instructions? If so, what is the URL? NO
