Request error showing in Grafana Dashboards with Elasticsearch data source
We are observing the request error in multiple panel in grafana dashboard
Grafana v6.0.1
Elasticsearch 5.4.x
There’s probably something not working properly, then.
However, without knowing exactly what the error message you’re seeing is, we
can only guess at speculative causes, which is not especially helpful.
You give us enough information to understand the problem you’re having, and
we’ll try to help resolve it.
Regards,
Antony.
Hi Antony ,
Thanks for the reply and update. I fix this issue. Elasticsearch service was not running properly. So I restarted the service then issue fix. Thank You.
