Grafana v10.1.4 (a676a96d91) -
Replace zero values by 0
I have different values A/B/C for examples. The issue is when doing something like ($A||$B)&&($A||$C)&&($B||$C) and for example A has no value at one time, nothing is returned. -
What happened?
when one value is NULL, nothing is aggregated -
having a value each time -
($A||$B)&&($A||$C)&&($B||$C) -
No error only missing data -
welcome @jeremiemt
What is your data source?
Influx DB
your title says: Replace zero values by 0
You also say
and then
So which one is it? And can you share a screen capture?
Thanks
Is there someone that could help ?
Thanks in advance ![]()
Thank you for feedback.
I’ve tried your suggestion (and all other combination without success).
Did I forget something ?
I’ve tried to do a transformation on P series, using same config that you did but it removes everything.
