I have the bellow panel where I need to filter out some of the series by a regex:
I am using regex /Time|BYTES_RX_THROUGHPUT/ to select series that I am interested in.
Is there a way to replace the maching ‘BYTES_RX_THROUGHPUT’ keyword with empty string?
This would help me only to match series for Time or series which contain BYTES_RX_THROUGHPUT and if they contain BYTES_RX_THROUGHPUT just remove the keyword to obtain only the IP.
Thanks,
Victor
