Grafana 9.1.8 -
Repeating rows in dashboard based on variable -
Variable type Custom with comma separated values
It works fine for none repeating rows dashboard -
What happened?
Single quote marks get inserted and query breaks
When adding a row that is repeating on the variuable, then the expression used in the query where the variable is part of the query gets expanded and single quote marks are added around the variable result. -
no extra characters to be added around the variable expansion -
I have the following variable defined: asset
custom values: line_1/row_1, line_1/row_2, line_2/row_1
In a dashboard with repeating rows the query gets expanded as follows:
Query template:
SELECT *
FROM table
WHERE
time BETWEEN ‘2023-09-21T04:51:12.338Z’ AND ‘2023-09-21T10:51:12.338Z’ AND topic = ‘root/${asset}/energy’ AND
When using repeat rows this gets expanded to:
topic = ‘root/‘line_1/row_1’/energy’
When not using repeat then it gets expanded to:
topic = root/line_1/row_1/energy’
db query error: pq: syntax error at or near “line_1” -
no
