Hello, I’m working with table panel, When I try to eliminate the title of the panel, there is only one heart. but I need to eliminate the field in general.
I need it to be as in the following image
thank you very much, greetings
It seems like you have an alert defined for your panel. That’s very interesting since as far as I know you cannot have alerts on tabel panels. If you get rid of the alert you should get the desired result.
You may need to edit the json data to resolve this.
Marcus
thank you very much, edit the json and it worked. regards
