Appreciate your kind help - I have built an awesome dashboard BUT have added in the end some test table and saved the dashboard.
Now I would like to remove that test table - but the trash icon not works and also and also the remove option in left navigation not works !
Can you please advise how to delete the non-used table?
Thanks
Ron
Thanks for the assistance. Yes Iโve tried both the trash icon and row options but non of them works.
In the end I built a new dashboard without this panel.
