Hi all,
I have a chart representing kW consumed per hour, as in the picture. I can’t seem to figure out how to remove the “kw” on top of every bar. Can anyone help me with this please? i.e. “7.14 kW” to “7.14” The unit of measurement I am using is Watts btw.
Thank you in advance, Sunny
May be specifying Unit as Number and Axis - Label as kW would work for your case:
Thanks so much buddy. Worked a treat!
I have an issue with the timings now… It shows as energy used from 00:00 - 01:00 as 01:00… which means when it gets to the end of the day I’m missing an hour of data… 00:00 which should represent 23:00 - 01:00. I’ll start a new thread for this issue here.
