I am using a table panel and Filter menu. When I select a smaller time range (< 6 months) and filter on some fields, filter menu shows “remove filter” option. But when I change it to time range of 6 months to now (or any older time - now) for the same record it doesn’t show “remove filter” option on filter menu!
What could be the reason ?
