Hi
I am using html panel to show the application list. I have also seen this same issue with other panels. I see huge gap/space between two panels which is not used. How can I remove this extra padding between two panels. Please help.
As you see in the image there is huge space between two panels where it goes waste and if you have a requirement to fit more panels in one page you cannot do that.
