Release Notes v7.3.x
Grafana v7.3 brings new features, many enhancements and bug fixes.
7.3.10 (2021-03-18)
Bug fixes
  • Security: Fix API permissions issues related to team-sync CVE-2021-28146, CVE-2021-28147. (Enterprise)
  • Security: Usage insights requires signed in users CVE-2021-28148. (Enterprise)
7.3.7 (2021-01-14)
Bug fixes
  • Auth: Add missing request headers to SigV4 middleware allowlist. #30115, @wbrowne
  • Elasticsearch: Sort results by index order as well as @timestamp. #29761, @STEELBADGE
  • SAML: Fix bug in processing SAML response with empty Issuer element. #30179, @alexanderzobnin
  • SeriesToRows: Fix issue in transform so that value field is always named Value. #30054, @torkelo
7.3.5 (2020-12-10)
Features and enhancements
  • Alerting: Improve Prometheus Alert Rule error message. #29390, @wbrowne
Bug fixes
  • Alerting: Fix alarm message formatting in Dingding. #29482, @tomowang
  • AzureMonitor: Fix unit translation for MilliSeconds. #29399, @secustor
  • Instrumentation: Fix bug with invalid handler label value for HTTP request metrics. #29529, @bergquist
  • Prometheus: Fixes problem where changing display name in Field tab had no effect. #29441, @zoltanbedi
  • Tracing: Fixed issue showing more than 300 spans. #29377, @zoltanbedi
7.3.4 (2020-11-24)
Bug fixes
  • Dashboard: Fixes kiosk state after being redirected to login page and back. #29273, @torkelo
  • InfluxDB: Update flux library to fix support for boolean label values. #29310, @ryantxu
  • Security: Fixes minor security issue with alert notification webhooks that allowed GET & DELETE requests. #29330, @wbrowne
  • Table: Fix incorrect condition for rendering table filter. #29165, @dprokop
7.3.3 (2020-11-17)
Features / Enhancements
Bug Fixes
  • Cloud monitoring: Fix for multi-value template variable for project selector. #29042, @papagian
  • LogsPanel: Fix scrolling in dashboards. #28974, @aocenas
  • StatPanel: Fixes hanging issue when all values are zero. #29077, @torkelo
  • Thresholds: Fixes color assigned to null values. #29010, @torkelo
7.3.2 (2020-11-11)
  • CloudWatch Logs: Change how we measure query progress. #28912, @aocenas
  • Dashboards / Folders: delete related data (permissions, stars, tags, versions, annotations) when deleting a dashboard or a folder. #28826, @AgnesToulet
  • Gauge: Improve font size auto sizing. #28797, @torkelo
  • Short URL: Cleanup unvisited/stale short URLs. #28867, @wbrowne
  • Templating: Custom variable edit UI, change options input into textarea. #28322, @darrylsepeda
7.3.1 (2020-10-30)
Bug Fixes
  • Cloudwatch: Fix duplicate metric data. #28642, @zoltanbedi
  • Loki: Fix error when some queries return zero results. #28645, @ivanahuckova
  • PanelMenu: Fix panel submenu not being accessible for panels close to the right edge of the screen. #28666, @torkelo
  • Plugins: Fix descendent frontend plugin signature validation. #28638, @wbrowne
  • Prometheus: Fix copy paste behaving as cut and paste. #28622, @aocenas
  • StatPanel: Fix value being under graph and reduced likelihood for white and dark value text mixing. #28641, @torkelo
  • TextPanel: Fix problems where text panel would show old content. #28643, @torkelo
7.3.0 (2020-10-28)
Bug Fixes
  • Alerting: Log warnings for obsolete notifiers when extracting alerts and remove frequent error log messages. #28162, @papagian
  • Auth: Fix SigV4 request verification step for Amazon Elasticsearch Service. #28481, @wbrowne
  • Auth: Should redirect to login when anonymous enabled and URL with different org than anonymous specified. #28158, @marefr
  • Elasticsearch: Fix handling of errors when testing data source. #28498, @marefr
  • Graphite: Fix default version to be 1.1. #28471, @ivanahuckova
  • StatPanel: Fixes BizChart error max: yyy should not be less than min zzz. #28587, @hugohaggmark
7.3.0-beta2 (2020-10-22)
Bug Fixes
7.3.0-beta1 (2020-10-15)
Breaking changes
  • CloudWatch: The AWS CloudWatch data source’s authentication scheme has changed. See the upgrade notes for details and how this may affect you.
Bug Fixes
  • Azure Analytics: FormatAs Time series groups bool columns wrong. #27713
  • Azure: Fixes cancellation of requests with different Azure sources. #28180, @hugohaggmark
  • BackendSrv: Reloads page instead of redirect on Unauthorized Error. #28276, @hugohaggmark
  • Dashboard: Do not allow users without edit permission to a folder to see new dashboard page. #28249, @torkelo
  • Dashboard: Fixed issue accessing horizontal table scrollbar when placed at bottom of dashboard. #28250, @torkelo
  • DataProxy: Add additional settings for dataproxy to help with network proxy timeouts. #27841, @kahinton
  • Database: Adds new indices to alert_notification_state and alert_rule_tag tables. #28166, @KarineValenca
  • Explore: Fix showing of Prometheus data in Query inspector. #28128, @ivanahuckova
  • Explore: Show results of Prometheus instant queries in formatted table. #27767, @ivanahuckova
  • Graph: Prevent legend from overflowing container. #28254, @jackw
  • OAuth: Fix token refresh failure when custom SSL settings are configured for OAuth provider. #27523, @billoley
  • Plugins: Let descendant plugins inherit their root’s signature. #27970, @aknuds1
  • Runtime: Fix handling of short-lived background services. #28025, @ahlaw
  • TemplateSrv: Fix interpolating strings with object variables. #28171, @torkelo
  • Variables: Fixes so constants set from url get completed state. #28257, @hugohaggmark
  • Variables: Prevent adhoc filters from crashing when they are not loaded properly. #28226, @mckn
Is the access door no longer 3000? I updated here and I can’t access it anymore.
The default port of 3000 has not changed. Did you figure out how to get it working?
I cant seem to find any Release Notes nor changelog on v 7.3.6 (released dec 17 2020).
or maybe it was just a minor release not needing notes?
(btw, i love the constant work and updates being done upon grafana, its really great- thanks!)
(LOVE grafana!)
7.3.6 was a security release for Grafana enterprise (SAML issue). See https://github.com/grafana/grafana/blob/master/CHANGELOG.md
