Grafana v6.2 brings new features, many enhancements and bug fixes.
6.2.5 (2019-06-25)
Features / Enhancements
Grafana-CLI: Wrapper for
grafana-cliwithin RPM/DEB packages and config/homepath are now global flags. #17695, @gotjosh - Panel: Fully escape html in drilldown links (was only sanitized before) . #17731, @dehrax
Bug Fixes
- Config: Fix connectionstring for remote_cache in defaults.ini. #17675, @kylebrandt
- Elasticsearch: Fix empty query (via template variable) should be sent as wildcard. #17488, @davewat
- HTTP-Server: Fix Strict-Transport-Security header. #17644, @kylebrandt
- TablePanel: fix annotations display. #17646, @ryantxu
6.2.4 (2019-06-18)
Bug Fixes
- Grafana-CLI: Fix receiving flags via command line . #17617, @gotjosh
- HTTPServer: Fix X-XSS-Protection header formatting. #17620, @yverry
6.2.3 (2019-06-17)
Known issues
grafana-cli: The argument
--pluginsDiris not working. -
docker: Due to above problem with grafana-cli the docker run will fail to start the container if you’re installing plugins using the
GF_INSTALL_PLUGINSenvironment variable. We have removed 6.2.3 tag from docker hub and latest tag now points to 6.2.2.
More details in bug report: https://github.com/grafana/grafana/issues/17613
- AuthProxy: Optimistic lock pattern for remote cache Set. #17485, @papagian
- HTTPServer: Options for returning new headers X-Content-Type-Options, X-XSS-Protection and Strict-Transport-Security. #17522, @kylebrandt
Bug Fixes
- Auth Proxy: Fix non-negative cache TTL. #17495, @kylebrandt
- Grafana-CLI: Fix receiving configuration flags from the command line. #17606, @gotjosh
- OAuth: Fix for wrong user token updated on OAuth refresh in DS proxy. #17541, @redbaron
- remote_cache: Fix redis. #17483, @kylebrandt
6.2.2 (2019-06-05)
Bug Fixes
- CloudWatch: Fixes error when hiding/disabling queries . #17283, @jpiccari
- Database: Fixed slow permission query in folder/dashboard search. #17427, @aocenas
- Explore: Fixed updating time range before running queries. #17349, @marefr
- Plugins: Fixed plugin config page navigation when using subpath. #17364, @torkelo
6.2.1 (2019-05-27)
- CLI: Add command to migrate all datasources to use encrypted password fields . #17118, @aocenas
- Gauge/BarGauge: Improvements to auto value font size . #17292, @torkelo
Bug Fixes
- Auth Proxy: Resolve database is locked errors. #17274, @marefr
- Database: Retry transaction if sqlite returns database is locked error. #17276, @marefr
- Explore: Fixes so clicking in a Prometheus Table the query is filtered by clicked value. #17083, @hugohaggmark
- Singlestat: Fixes issue with value placement and line wraps. #17249, @torkelo
- Tech: Update jQuery to 3.4.1 to fix issue on iOS 10 based browers as well as Chrome 53.x . #17290, @timbutler
6.2.0 (2019-05-22)
Bug Fixes
- BarGauge: Fix for negative min values. #17192, @torkelo
- Gauge/BarGauge: Fix for issues editing min & max options. #17174
- Search: Make only folder name only open search with current folder filter. #17226
- AzureMonitor: Revert to clearing chained dropdowns. #17212
Breaking Changes
- Plugins: Data source plugins that process hidden queries need to add a “hiddenQueries: true” attribute in plugin.json. #17124, @ryantxu
6.2.0-beta2 (2019-05-15)
- Plugins: Support templated urls in plugin routes. #16599, @briangann
- Packaging: New MSI windows installer package**. #17073, @briangann
Bug Fixes
- Dashboard: Fixes blank dashboard after window resize with panel without title. #16942, @torkelo
- Dashboard: Fixes lazy loading & expanding collapsed rows on mobile. #17055, @torkelo
- Dashboard: Fixes scrolling issues for Edge browser. #17033, @jschill
- Dashboard: Show refresh button in first kiosk(tv) mode. #17032, @torkelo
- Explore: Fix empty result from datasource should render logs container. #16999, @marefr
- Explore: Makes it possible to zoom in Explore/Loki/Graph without exception. #16991, @hugohaggmark
- Gauge: Fixes orientation issue after switching from BarGauge to Gauge. #17064, @torkelo
- GettingStarted: Fixes layout issues in getting started panel. #16941, @torkelo
- InfluxDB: Fix HTTP method should default to GET. #16949, @StephenSorriaux
- Panels: Fixed alert icon position in panel header. #17070, @torkelo
- Panels: Fixes panel error tooltip not showing. #16993, @torkelo
- Plugins: Fix how datemath utils are exposed to plugins. #16976, @marefr
- Singlestat: fixed centering issue for very small panels. #16944, @torkelo
- Search: Scroll issue in dashboard search in latest Chrome. #17054, @jschill
- Docker: Prevent a permission denied error when writing files to the default provisioning directory. #16831, @wmedlar
- Gauge: Adds background shade to gauge track and improves height usage. #17019, @torkelo
- RemoteCache: Avoid race condition in Set causing error on insert. . #17082, @bergquist
6.2.0-beta1 (2019-05-07)
- Admin: Add more stats about roles. #16667, @bergquist
- Alert list panel: Support variables in filters. #16892, @psschand
- Alerting: Adjust label for send on all alerts to default . #16554, @simPod
- Alerting: Makes timeouts and retries configurable. #16259, @kobehaha
- Alerting: No notification when going from no data to pending. #16905, @bergquist
- Alerting: Pushover alert, support for different sound for OK. #16525, @Hofls
- Auth: Enable retries and transaction for some db calls for auth tokens . #16785, @bergquist
- AzureMonitor: Adds support for multiple subscriptions per datasource. #16922, @daniellee
- Bar Gauge: New multi series enabled gauge like panel with horizontal and vertical layouts and 3 display modes. #16918, @torkelo
- Build: Upgrades to golang 1.12.4. #16545, @bergquist
- CloudWatch: Update AWS/IoT metric and dimensions. #16337, @nonamef
- Config: Show user-friendly error message instead of stack trace. #16564, @Hofls
- Dashboard: Enable filtering dashboards in search by current folder. #16790, @dprokop
- Dashboard: Lazy load out of view panels . #15554, @ryantxu
- DataProxy: Restore Set-Cookie header after proxy request. #16838, @marefr
- Datasources: Add pattern validation for time input on datasource config pages. #16837, @aocenas
- Elasticsearch: Add 7.x version support. #16646, @alcidesv
- Explore: Adds reconnect for failing datasource. #16226, @hugohaggmark
- Explore: Support user timezone. #16469, @marefr
- InfluxDB: Add support for POST HTTP verb. #16690, @StephenSorriaux
- Loki: Search is now case insensitive. #15948, @steven-sheehy
OAuth: Update jwt regexp to include
=. #16521, @DanCech - Panels: No title will no longer make panel header take up space. #16884, @torkelo
- Prometheus: Adds tracing headers for Prometheus datasource. #16724, @svagner
- Provisioning: Add API endpoint to reload provisioning configs. #16579, @aocenas
- Provisioning: Do not allow deletion of provisioned dashboards. #16211, @aocenas
- Provisioning: Interpolate env vars in provisioning files. #16499, @aocenas
- Provisioning: Support FolderUid in Dashboard Provisioning Config. #16559, @swtch1
- Security: Add new setting allow_embedding. #16853, @marefr
- Security: Store datasource passwords encrypted in secureJsonData. #16175, @aocenas
- UX: Improve Grafana usage for smaller screens. #16783, @torkelo
- Units: Add angle units, Arc Minutes and Seconds. #16271, @Dripoul
Bug Fixes
- Build: Fix bug where grafana didn’t start after mysql on rpm packages. #16917, @bergquist
- CloudWatch: Fixes query order not affecting series ordering & color. #16408, @mtanda
- CloudWatch: Use default alias if there is no alias for metrics. #16732, @utkarshcmu
- Config: Fixes bug where timeouts for alerting was not parsed correctly. #16784, @aocenas
- Elasticsearch: Fix view percentiles metric in table without date histogram. #15686, @Igor-Ratsuk
- Explore: Prevents histogram loading from killing Prometheus instance. #16768, @hugohaggmark
- Graph: Allow override decimals to fully override. #16414, @torkelo
- Mixed Datasource: Fix error when one query is disabled. #16409, @marefr
- Search: Fixes search limits and adds a page parameter. #16458, @torkelo
- Security: Responses from backend should not be cached. #16848, @marefr
Breaking changes
- Gauge Panel: The suffix / prefix options have been removed from the new Guage Panel (introduced in v6.0). #16870.
