The Grafana 6.1 release contains two major highlights and tons of small changes and fixes.
6.1.6 (2019-04-29)
Features / Enhancements
Bug Fixes
6.1.5 (2019-04-29)
File Exfiltration vulnerability Security fix
See security announcement for details.
6.1.4 (2019-04-16)
Bug Fixes
- DataPanel: Added missing built-in interval variables to scopedVars. #16556, @torkelo
- Explore: Adds maxDataPoints to data source query options . #16513, @hugohaggmark
- Explore: Fixes so intervals are recalculated on run query. #16510, @hugohaggmark
- Heatmap: Fix for empty graph when panel is too narrow (#16378). #16460, @alexanderzobnin
- Heatmap: Fixed auto decimals when bucket name is not number. #16609, @torkelo
- QueryInspector: Now shows error responses again. #16514, @torkelo
6.1.3 (2019-04-09)
Bug Fixes
Graph: Fixed auto decimals in legend values for some units like
msands. #16455, @torkelo - Graph: Fixed png rendering with legend to the right. #16463, @torkelo
- Singlestat: Use decimals when manually specified. #16451, @torkelo
- UI Switch: Fix broken UI switches. Fixes Default Data Source switch, Explore Logs switches, Gauge option switches. #16303, @dprokop
6.1.2 (2019-04-08)
Bug Fixes
- Graph: Fixed series legend color for hidden series. #16438, @Ijin08
- Graph: Fixed tooltip highlight on white theme. #16429, @torkelo
- Styles: Fixed menu hover highlight border. #16431, @torkelo
- Units: Correctly use the override decimals. #16413, @torkelo
6.1.1 (2019-04-05)
Bug Fixes
- Alerting: Notification channel http api fixes. #16379, @marefr
- Graphite: Editing graphite query function now works again. #16390, @torkelo
- Playlist: Kiosk & auto fit panels modes are working normally again . #16403, @torkelo
- QueryEditors: Toggle edit mode now always work on slower computers. #16394, @seanlaff
6.1.0 (2019-04-03)
Bug Fixes
- CloudWatch : Fix for dimension value list when changing dimension key. #16356, @mtanda
- Graphite : Editing function arguments now works again. #16297, @torkelo
- InfluxDB : Fix tag names with periods in alert evaluation. #16255, @floyd-may
- PngRendering : Fix for panel height & title centering . #16351, @torkelo
- Templating : Fix for editing query variables. #16299, @torkelo
6.1.0-beta1 (2019-03-27)
New major features:
- Prometheus: Ad hoc Filtering makes it easier to explore data in a Grafana dashboard.
- Permissions: A new option so that Editors can own dashboards, folders and teams they create. This makes it easier for teams to self-organize when using Grafana.
New Features
- Prometheus : adhoc filter support #8253, thx @mtanda
- Permissions : Editors can become admin for dashboards, folders and teams they create. #15977, @xlson
Minor
- Auth : Support listing and revoking auth tokens via API #15836
- Alerting : DingDing notification channel now includes alert values. #13825, @athurg
- Alerting : Notification channel http api enhancements. #16219, @marefr
- CloudWatch : Update metrics/dimensions list. #16137, @mtanda
- Cloudwatch : Add AWS RDS MaximumUsedTransactionIDs metric #15077, thx @activeshadow
- Cache : Adds support for using out of proc caching in the backend #10816
Dashboard : New keyboard shortcut
d ltoggles all Graph legends in a dashboard. #15770, @jsferrei - Datasource : Only log connection string in dev environment #16001
- DataProxy : Add custom header (X-Grafana-User) to data source requests with the current username. #15998, @aocenas
- DataProxy : Make it possible to add user details to requests sent to the dataproxy #6359 and #15931
- DataProxy : Adds oauth pass-through option for datasources. #15205, @seanlaff
- Explore : Hide empty duplicates column in logs viewer. #15982, @steven-sheehy
- Explore : Make it possible to close left pane of split view. #16155, @dprokop
- Explore : Move back / forward with browser buttons now works. #16150, @hugohaggmark
- Explore : Update Loki labels when label selector is opened. #16131, @dprokop
- Graph Panel : New options for X-axis Min & Max (for histograms). #14877, @papagian
- Heatmap : You can now choose to hide buckets with zero value. #15934, @alexanderzobnin
Heatmap :
Middlebucket bound option #15683 -
Heatmap :
Reverse orderoption for changing order of buckets #15683 - Prometheus : Change alignment of range queries to end before now and not in future. #16110, @davkal
- Prometheus : Dedup annotations events with same timestamp . #16152, @torkelo
- SQL : Use default min interval of 1m for all SQL data sources. #15799, @marefr
- TablePanel : Column color style now works even after removing columns. #16227, @torkelo
- Templating : Custom variable value now escapes all backslashes properly. #15980, @srid12
- Templating : Data source variable now supports multi-value for uses cases that involve repeating panels & rows. #15914, @torkelo
- VictorOps : Adds more information to the victor ops notifiers #15744, thx @zhulongcheng
Bug Fixes
- Alerting : Don’t include non-existing image in MS Teams notifications. #16116, @SGI495
- Api : Invalid org invite code #10506
- Annotations : Fix for native annotations filtered by template variable with pipe. #15515, @marefr
- Dashboard : Fix for time regions spanning across midnight. #16201, @marefr
- Datasource : Handles nil jsondata field gracefully #14239
- Datasource : Empty user/password was not updated when updating datasources #15608, thx @Maddin-619
- Elasticsearch : Fixes using template variables in the alias field. #16229, @daniellee
- Elasticsearch : Fix incorrect index pattern padding in alerting queries. #15892, @sandlis
- Explore : Fix for Prometheus autocomplete not working in Firefox. #16192, @hugohaggmark
- Explore : Fix for url does not keep query after browser refresh. #16189, @hugohaggmark
- Gauge : Interpolate scoped variables in repeated gauges #15739
- Graphite : Fixed issue with using series ref and series by tag. #16111, @torkelo
- Graphite : Fixed variable quoting when variable value is nummeric. #16149, @torkelo
- Heatmap : Fixes Y-axis tick labels being in wrong order for some Prometheus queries. #15932, @alexanderzobnin
- Heatmap : Negative values are now displayed correctly in graph & legend. #15953, @alexanderzobnin
- Heatmap : legend shows wrong colors for small values #14019
- InfluxDB : Always close request body even for error status codes. #16207, @ramongtx
- ManageDashboards : Fix for checkboxes not appearing properly Firefox . #15981, @srid12
- Playlist : Leaving playlist now always stops playlist . #15791, @peterholmberg
- Prometheus : fixes regex ad-hoc filters variables with wildcards. #16234, @daniellee
- TablePanel : Fix for white text on white background when value is null. #16199, @peterholmberg
