Hi !
after a long break I‘ve made my network topology visualization plugin 2x more user-friendly and in-line with native Grafana field config and standard behaviors.
Major Mapgl 2.0. update in the Grafana catalog features:
Geo + Node Graph view with autolayout and spline edge routing that respects node boundary curves.
Arc sections on nodes for any metrics.
Multi-segment routes
Style config extending Grafana Geomap UI and styles-from-dimensions concept with overrides for user-defined node groups
Network interface TX/RX load visualization using bi-metric arcs
Layer filters and node groups legend
Unified (Graph+Geo) single dataframe for nodes and edges (same as in v.1) that avoids hardcoded dataframe requirements of the native Geomap/NodeGraph.
Native Grafana Field config support: Thresholds, Mappings, Units, Overrides
Dynamic drill-down data links from nodes and edges to external panels.
