Hi there,
I’m using Grafana (7.3.6) with an Influxdb Datasource.
Before the Upgrade to 7.3.6 I could use the “Relative time”-Option (under Query options) to be a little bit more independent from the timepicker.
After the Upgrade it seems to have no function at all. You can type whatever you want in this field and nothing happens - the timespan checked with the Query inspector - is allway the same you chose with the timepicker.
I recognized some additional configuration abilities in the grafana.ini file for Date-Formats and this I used for a more convenient touch.
So how can I solve this problem?
Erik
