v10.1.1
I am trying to convert the value of the following metric to a version string:
{pg_settings_server_version_num{container=~"postgres.*", postgres_partition=~"$tenant.*", cluster=~"$cluster"}
This returns150012, which corresponds to version15.12.
Data source is thanos. -
I tried to use a regex value mapping like this:
( \d\d)\d\d(\d\d)=>$1.$2 -
What happened?
Nothing, it doesn’t work. I suspect because the value is an integer, not a number. -
I assumed, that grafana would automatically convert a value to string if the user applies a regex mapping. Otherwise the option should not be available. -
Did you receive any errors in the Grafana UI or in related logs?
Nope.
