Both Grafana on-prem (Docker, Grafana v10.3.1 (00a22ff8b2)) and SaaS (Grafana v10.4.0-65875 (b758b91e84)), -
I want to achieve the value mapping for throughput value in panel. For example, if the value of throughput 0 Mb/s to 5 Mb/s indicate “Good” whereas 5.1 Mb/s to 10Mb/s “Critical” -
I’m trying using regex value mapping -
What happened?
There is no value mapping success even I had put the regex format -
Good (0 Mb/s to 5 Mb/s)
Critical (5.1 Mb/s to 10 Mb/s) -
There is no error -
Welcome @zulhilmisamsuddin
Does kentik actually save the data as string 10Mb/s ?
As per checking and my team understanding, the data type using number. Kindly find the attached screenshot.
Is it any alternative to use the value mapping to override the value display at the column?
