Regex to convert a variable for a Dashboard to uppercase
    Windows 2019 Server
    I have some variables I’ve created that need to be converted to uppercase to be pushed into a query I am doing against Log Analytics Workspace. These are SQL audit logs related, and it unfortunately case sensitive. My current variables are being extracted as lowercase and this breaks the query. I have tested the same query by manually using uppercase and it works fine.
subid / resource / sql variables all need to be uppercase to work, the db variable is fine however.
Query below;
AzureDiagnostics
| where Category == ‘SQLSecurityAuditEvents’
| where ResourceId == ‘/SUBSCRIPTIONS/$subid/RESOURCEGROUPS/$resource/PROVIDERS/MICROSOFT.SQL/SERVERS/$sql/DATABASES/MASTER’ and database_name_s == ‘$db’
| project
event_time_t,
statement_s,
succeeded_s,
affected_rows_d,
server_principal_name_s,
client_ip_s,
application_name_s,
additional_information_s,
data_sensitivity_information_s
| order by event_time_t desc
| take 100
    Setting up a Azure SQL Audit Logs Dashboard.
  • What happened?
    All me variables are being extracted as lowercase
can you try the upper() function in your sql?
/SUBSCRIPTIONS/upper($subid)/RESOURCEGROUPS/upper($resource)/PROVIDERS/MICROSOFT.SQL/SERVERS/upper($sql)/DATABASES/MASTER’ and database_name_s == ‘$db’
No joy amended the query string to use upper() function, query still fails.
Thanks for your help.
Resource Graph Query works
Resources
| where type == “microsoft.sql/servers” | extend Id=toupper(subscriptionId)
| project toupper(id)
