According to grafana-url/api/health :
“commit”: “a676a96d91”,
“database”: “ok”,
“version”: “10.1.4”
Device info (in case it matters)
|Description:|Ubuntu 22.04.3 LTS|
|Release:|22.04|
(I’m very new to grafana, trying it out for a college project, any help is appreciated)
What are you trying to achieve? :
I want to extract the packet loss percentage from the ‘message’
I tried using the value mapping, I even tried the same with “rename by regex” transform tool, and cheked out other community posts.
my regex code works properley here :
What happened? Nothing (It still shows message as a string, with no modifications)
What did you expect to happen? Well, The packet loss to be shown as a number (I want to plug the value into a gauge)
and also ( rename-by-regex-doesnt-process-validated-syntax/82305 )
Please let me know If I’m missing something small, I’ve been trying to figure this out for days now.
Thank you!
