Hey guys, I am pulling Sensu data into Grafana via InfluxDB. I want to have Templating build around subscriptions but I can not get a regex to match. The subscriptions are separated by “:”, so i need the regex to exclude. I tried more than a few options with no luck including ([^:]+)/g.
When I use https://regex101.com/, ([^:]+)/g. works great.
Linux_Servers:Docker:Vision_Hosts
Linux_Servers:Docker:Vision_Hosts:Database_Servers
Linux_Servers:WAS_Testing
Thanks for the help!!
I don’t understand what you’re trying to accomplish. Do you want to get rid of sensu: or all :?
Marcus
I want to split the names, this is how it looks today:
So I want to break it down like this:
Linux_Servers
Vision_Hosts
Database_Servers
I’m afraid you cannot do that with regex in Grafana. Only possibility is if influxdb has that functionality so that you can accomplish what you want/need query wise.
Marcus
Ok, thank you for your help
