v9.2.4 -
Refreshing data -
Pressing the refresh button on grafana (not brower). -
What happened?
I see different data on each refresh eventhough my time range is fixed. I am not using relative time. -
I expect to see the same data. -
N/A -
No
What’s that “fixed” time range? Last [hour/day/week/month]? ![]()
Use the query inspector and provide queries, which were executed and their result was different.
The fixed time range is a yyy-mm-dd hour:minute. Taking grafana out of the equation. When I run the query (postgresql) I too get different results. So, I am not sure why thats happening…
You should know your data - maybe it’s live changing. it’s not a Grafana issue.
that is a date time format not a time range. what is the time range in date picker? or in the query itself?
May be you are using LIMIT keyword in your query without ORDER BY or something else. At least you checked that Grafana results are consistent with datasource, so it’s not a Grafana issue
