Is it possible to reduce the padding of the table cells ?
Because that’s a lot of space wasted, especially if you change the font size.
Example, on the left, the current settings and on the right, what I would like to have:
Thanks!
Thanks!
This is not possible without code modifications
Ok, I created a new PR for this feature, here: https://github.com/grafana/grafana/pull/9803
