Reducing alert labels
Hi there!
Is it possible to reduce the labels that are assigned to an alert?
e.g. remove the helm chart label or the cluster, etc.
This is from a multi-dimensional alert, if that matters.
Thanks a lot!
Kind regards
Dennis
Ah! I’ve found it myself. You simply add an aggregation function to the initial queries only reducing them to the required labels.
how to add this function?
Hello @ykarayildiz1140,
I assume you are using Prometheus data source:
Configuration:
Result:
Best regards,
ldrascic
