I’m working on a docker-compose file for running a local setup of a service for development and testing. This includes a Grafana dashboard and I have a dashboard as a YAML together with its JSON description that it configures when starting the docker-compose.
What annoys me is that if I go to localhost:3000, which currently runs Grafana, I need to go to the dashboards menu and select my dashboard to view it. Is it possible to somehow in the Grafana YAML configs make a particular dashboard the frontpage?
I looked at that setting and it’s easy to change that configuration in an existing server with a config file that I can easily edit. In this case, I’m just relying on the Grafana default docker image and I provision a dashboard into it like so:
Is there a way to make the provisioned dashboard a default or do I need to mount over a config over the existing config in the official Grafana docker image?
