Reading data from external html into grafana
Hello I have ESP8266 boards running webservers to display stats. I would like to create panels for each one to read the html data they display then display in grafana. Is there a way to do this? The html code displays @@DEVICE@@ @@ID@@ etc etc. Thank you in advance.
Welcome to the forum.
Remember that Grafana is a tool for visualizing time series data that is usually stored in a time series database (like InfluxDB), so you have to set up a time series database to store your ESP8266 stats.
This guide should get you started.
Here is another possible way to skip the MQTT+database and connect your HTML datasource directly to Grafana. Infinity plugin for Grafana | Grafana Labs
great ty!!! i think this is what i wanted. The ESP8266 runs a webserver that grabs these values i just want to take the values and visualie them in grafana I put the values i wanted in bold
**10.34kH/s**
**Hashrate**
392
**Difficulty**
**15953**
Shares
**star-pool-1**
Node
Device information
ESP8266
Device type
asteroids
Device ID
40056
Free memory
3.0
actually looking at the code from the webserver there is no class identified other than div class can i modify the html with a class I can pull from?
I have no experience with that plugin. I suggest you create a thread on the infinity plugin github page with an detailed explanation of your issue and data.
