React fiber three not supporting in grafana app plugin and panel plugin
import React, { useRef, useState } from “react”
import { Canvas, useFrame } from ‘@react-three/fiber’
function Box(props: any) {
// This reference will give us direct access to the mesh
const meshRef = useRef()
// Set up state for the hovered and active state
const [hovered, setHover] = useState(false)
const [active, setActive] = useState(false)
// Subscribe this component to the render-loop, rotate the mesh every frame
//@ts-ignore
useFrame((state, delta) => (meshRef.current.rotation.x += delta))
// Return view, these are regular three.js elements expressed in JSX
return (
<mesh
{…props}
ref={meshRef}
scale={active ? 1.5 : 1}
onClick={(event) => setActive(!active)}
onPointerOver={(event) => setHover(true)}
onPointerOut={(event) => setHover(false)}>
<boxGeometry args={[1, 1, 1]} />
<meshStandardMaterial color={hovered ? ‘hotpink’ : ‘orange’} />
interface Props{
export const BuildingViewer: React.FC = (props) => {
return(<>
React fiber three not working in App plugin and Panel plugin its throwing below error
Hi @jcsnaren :wave:
Which version of @react-three/fiber are you using, and also which Grafana are you trying to run it in? Can it be that this is connected to the warning “Multiple instances of Three.js being imported”?
Hi @leventebalogh Grafana latest version Release 10.4.1 (2024-03-20) · grafana/grafana · GitHub,
Rect-fiber-three Version is 8.16.0,
Please ignore "Multiple instances of Three.js being imported”? Warning
Hi @leventebalogh :wave: Any update in this issue?
Hi @leventebalogh
I posted a solution in another here
I forgot this topic was open so I made a new one, since 1y has passed I assumed it was closed too
