Metrics not visible in ‘rate’ column in the HTML report
Hi @Naveen
Welcome to the community forum ![]()
It will help is you give us a bit more context:
- Are you using GitHub - benc-uk/k6-reporter: Output K6 test run results as formatted & easy to read HTML reports for the html reports?
- Can you share screenshots so we can get more context?
- Can you share the (sanitized) script that you are using, and the command you are using run the test?
- Do you see any errors in the console? It also helps if you share the full output of the test.
Cheers!
