Could someone explain why the $__range variable has limited availability in datasources as mentioned here: Add variables | Grafana documentation
I am trying to use it in a promql query for a Cloud Monitoring datasource. Isn’t in the end the same mechanism used for $__interval variable which is available? I don’t understand what is different about the range.
