i have configured rabbitmq and successfully getting data in grafana. but how can i see the “message in queue matric” in grafana. Any help would be appriciated
Please include more information for us to be able to help you.
What data source are you using, e.g. influxdb, graphite, elasticsearch, prometheus?
How are you getting data into that data source from rabbitmq, e.g. telegraf, collectd, prometheus exporter?
Marcus
Thanks for the reply. here are the details of my setup.
- data source: graphite
- I am using collectd to send data to graphite.
below is the configuration file.
Globals true
LogTraces true
Interactive false
Import “collectd_rabbitmq_monitoring”
# Adjust these parameters for your install:
interval 10
host "localhost"
port 15672
username xxxxxxx
password xxxxxxxxxxxxxxxxxxx
LoadPlugin write_graphite
<Node "x.x.x.x">
Host "x.x.x.x"
Port "2003"
Protocol "tcp"
LogSendErrors true
Prefix "collectd.x.x.x.x.x"
StoreRates true
AlwaysAppendDS false
EscapeCharacter "_"
</Node>
If the collectd_rabbitmq_monitoring are extracting the data you’re looking for it should be rather easy for you to find the metric using Grafana and Graphite. If not, you have to modify the collectd_rabbitmq_monitoring or start using some other plugin that supports what you want.
I can see that you created an issue over at https://github.com/akrzos/collectd-rabbitmq-monitoring/issues/5 (or I think it’s you). I think you have better luck getting an answer in the issue than here.
Marcus
yes i am getting the data in grafana graphite from rabbitmq. but i want to see the message in queue as well. dont know much about this. so looking for some help.
Yeah but does the collectd_rabbitmq_monitoring extract and store the message in queue to graphite? If not, I cannot help you.
Marcus
Hi, I need to setup RabbitMQ for monitoring in Grafana. Could you please provide detailed documentation, so that i can follow the same steps and get the data in Grafana from RabbitMQ.
Thank You.
