Question to Disk R/W Data / Disk R/W Time
i hope someone here can point me in the right direction. I use CentOS Linux 7.8.2003 (Core)‬ in a virtuozzo container, and installed now Grafana + Prometheus with node exporter and imported Dashboard 1860. When i check the Dashboard CPU, Memory etc are Displayed correctly, but when i check Disk R/W Data and Disk R/W Time no values are shown in the Dashboard. Is it somehow possible, to get the Disk IO even in a Virtuaozzo Container??
Thx
Best regards
Chriss
no, this is not possible.
Thanks for the Information. I can measure with iotop and fio for example the disk performance, is there not a way to get this information to Prometheus / Grafana somehow?
no, that is not possible
good answers melrose, seems like a auto reply!
if you keep asking the same things you will get the same answers
