Question: Loki Alerting – Inconsistent Data in Alert Notifications
Setup:
I have configured an alert to send data if error requests are above 2%, using Loki as the datasource. My log ingestion flow is:
ALB > S3 > Python script downloads logs and sends them to Loki every minute.
Alerting Queries Configured:
  • A:
sum(count_over_time({job="logs"} | json | status_code != "" [10m]))
(Total requests in the last 10 minutes)
  • B:
sum(count_over_time({job="logs"} | json | status_code=~"^[45].." [10m]))
(Total error requests—status codes 4xx/5xx—in the last 10 minutes)
  • E:
sum by (endpoints, status_code) (
(Error requests grouped by endpoint and status code)
  • C:
math $B / $A * 100
(Error rate as a percentage)
  • F:
math ($A > 0) * ($C > 2)
(Logical expression: only true if there are requests and error rate > 2%)
  • D (Alert Condition):
threshold: Input F is above 0.5
(Alert fires if F is 1, i.e., both conditions above are met)
Sample Alert Email:
Below are the Total requests and endpoints
Total requests between 2025-05-04 22:30 UTC and 2025-05-04 22:40 UTC: 3729
Error requests in last 10 minutes: 97
Error rate: 2.60%
Top endpoints with errors (last 10 minutes):
- Status: 400, endpoints: some, Errors: 97
Alert Triggered At (UTC): 2025-05-04 22:40:30 +0000 UTC
Issue:
Sometimes I get correct data in the alert, but other times the data is incorrect. Has anyone experienced similar issues with Loki alerting, or is there something wrong with my query setup or alert configuration?
Any advice or troubleshooting tips would be appreciated!
