Failed to evaluate queries and expressions: input data must be a wide series but got type long (input refid)
Hello! I’m trying to setup notifications for loki source and the same query that works in “Explore” window doesn’t work in “Alert rules” window, I couldn’t find any info on this on the internet
So the query is {container="jetton-backend"} | json | status_code > 400
Here it is working in explore
And here is the same query that doesn’t work in alerts
Can anyone help please? Is there something i’m missing?
I have the same problem with alerting on logs with Loki & Promtail
Working on explore but not in alert.
Query: {namespace=“monitoring”} |= “0”
Response: “Failed to evaluate queries and expressions: input data must be a wide series but got type long (input refid)”
Any help would be apreciated
I was trying to figure this out too. From this Github issue I get the impression that Grafana alerting can only handle numeric data, not log messages.
So you can do a count of log messages matching a query, alert when the count is > 0, and then manually go looking through the logs when you get an alert, but as far as I can see there’s no way to actually get the log message contents.
Which seems nuts, so hopefully I’m missing something and someone else will chime in here with a better solution.
count(rate({container="jetton-backend"}} | json | status_code > 400 [$__interval]))
@sam2b3e is correct. Grafana Alerting works on numeric data, and Loki alerts are expected to use count or count_over_time.
Many thanks for confirming, it’s good to know I’m not missing the obvious :slight_smile:
I come from a world that uses Graylog and Elasticsearch for logging, so I’m used to being able to get log message contents in alerts, and it’s one of the first things I set out to do when evaluating Loki. I’m genuinely rather surprised that it can’t be done.
Is there anything in the roadmap that might address this in the future? Some method of having the alert notification template reference the underlying log data? I imagine it’d be a huge enabler for other people in my situation looking to move their logging over Loki (which in every other way is extremely compelling).
Heyy!! Guys I am also having same kind of problem,i am not able to fix that can anyone please rephrase here how to solve or give me the proper conclusion regarding with this please.
The trouble is when I’m using keywords to filter error logs use of few query that works in explore feature but not works in alert rules how to resolve this kind of stuffs
Query: {job=“sample”} |= “error” |=“https failed”
ERROR: Failed to evaluate queries and expressions: input data must be a wide series but got type long
Hi @here
Can you please us the following:
1- Is this reproducible only in a Containerized environment e.g. Docker, Kubernetes OR is reproducible on any local setup with Grafana + Loki?
2- Is it reproducible with the current stable version of Grafana 10.x?
To answer point number two, I have reproduced this using grafana/grafana-oss:10.1.4-ubuntu (Docker)
Hi @flyingpork15
What is your Data source?
Looks like Microsoft SQL to me.
Correct
You could do a count for how many of those log entries you get and base a threshold off of that
Hi @usman.ahmad,
Have you been able to find out if we can alert on the error message (word) vs using “count”. Just wondering if we can capture the line that contains the word error to help assist with troubleshooting/correlation.
{job=“syslog”, host=~“.±MAAS-001”, message=~“(?i).critical.”}[5m] OR
{job=“syslog”, host=~“.±MAAS-001”} |~ “critical”
Hi @maaslumen1,
Welcome to the :grafana: community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community :slight_smile:
Unfortunaitely, I did not know about this and also I am not tracking much on alerting these days.
I would recommend that you create a new post in the Alerting Category as ask your question there by providing all the details.
This is key point.
The error input data must be a wide series but got type long occurs because the query is returning a set of logs, not numeric or time series data that Grafana Alerting can evaluate. From docs:
Alerting can work with two types of data:
  1. Time series data — The query returns a collection of time series, where each series must be reduced to a single numeric value for evaluating the alert condition.
  2. Tabular data — The query must return data in a table format with only one numeric column. Each row must have a value in that column, used to evaluate the alert condition. See a tabular data example.
When querying logs from Loki, you need to use functions like count or count_over_time to turn your logs into numbers that can be compared in alert conditions.
For example, instead of using a raw log query like:
{job="syslog", host=~".+-MAAS-001", message=~"(?i).critical."}[5m]
you should use something like:
count_over_time({job="syslog", host=~".+-MAAS-001", message=~"(?i).critical."}[5m])
This returns the number of matching log lines over a 5-minute window, which you can then compare to a threshold in your alert rule.
For a quick example, check out the Tutorial: Create alerts with logs.
