cokewl
1
Good morning, everyone,
First of all, I thank you for your tool which is just great!
I have a small problem and I can’t solve it, I installed grafana with a simple apt install, it works perfectly.
But I can’t understand how to install loki because on the git:
I only find a docked installation, which I don’t want.
So I told myself it must be in the basic package apt but I can’t find it anywhere and when I look but open port I’m not open port 3100.
I also noticed that in the docker version I had a loki data source that I can’t find in my installation I just loggin grafana.
Can you help me?
Thank you in advance.
@cokewl Have you had Loki installed? If so, how did you do it? thanks!
