Query with 8.2.4 results epoch time while 7.5.9 results 2021-11-18T00:00:00Z
I have data source as Postgres13.
My column contents are as below (given few rows only)
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-07”
“2021-10-14”
“2021-10-14”
“2021-10-14”
“2021-10-14”
“2021-10-14”
“2021-10-14”
“2021-10-14”
“2021-10-14”
If i add variable in Grafana with 8.2.4 with query
select distinct from where expirydate >= current_date order by 1 ASC limit 12
I am getting output as epoch time as below
1637193600000
1637798400000
1638403200000
1639008000000
1639612800000
1640217600000
1640822400000
1641427200000
1642032000000
1643241600000
1648684800000
1656547200000
While if I run same query in Grafana 7.5.9 to add variable I am getting
2021-11-25T00:00:00Z
2021-12-02T00:00:00Z
2021-12-09T00:00:00Z
2021-12-16T00:00:00Z
2021-12-23T00:00:00Z
2021-12-30T00:00:00Z
2022-01-06T00:00:00Z
2022-01-13T00:00:00Z
2022-01-27T00:00:00Z
2022-03-31T00:00:00Z
2022-06-30T00:00:00Z
What could be the issue?
@sharingideas are you saying that you want to convert that epoch format into a more human-readable timestamp?
I can’t say why this is happening or how to fix the core problem. But a workaround might be to fiddle with the Convert field type transformation…
also, this issue might be related. what do you think?
grafana/grafana#36404
