where the event can be captured by a ‘wifi alarm’ followed by a ‘wifi reset’ with a voltage increase of more than 1 volt.
I am able to get the data to capture one event, but I am not sure how to compare this to a previous event and verify the battery change over a short time.
SELECT * FROM AGV.dbo.AGVfault
WHERE $__timeFilter(TimeDate) AND Program <> 0 AND Program in ($Program) AND AGV in ($AGV) AND Fault = ‘wifi reset’ AND BattVoltage > 24.1
ORDER BY TimeDate desc
another possible way of detecting the event would be the two faults shown below occurring in the same minute, if this is easier to process?
Hi. I’m not really sure how to use the calculation tab?
I can manage to plot both query’s on the same chart to give a visual indication which shows the data I want to capture, but as you can see the time stamp for the two events, they are not exactly the same time, so I cant work out how to to capture this as one vent.
my solution so far is to use two query’s on the same chart and just use formatting to highlight where the two overlap. This works in a fashion, but is not very robust.
is it possible to combine the two query’s in to one, so that i can count the number of occurrences?
Hi. yes the data is captured at hh:mm:ss precision, and technically they occur at the same time, but due to delays in PLC comm’s they can be captured at slightly different times, +/- 3 seconds ish.
The events are alarm reset codes sent from AGV PLC’s to a master PLC then on to MySQL server, then to Grafana. The event I am trying to capture does not actually exist (battery change) as a single event, however by simulating the event I am able to view a selection of alarms generated and combine them to get the same result.
In a perfect world I would really like add in a voltage change, so before the events (V) = x then after the alarms (V) = x + >0.5
What is the unique value on all of those columns? Is there an eventid? Also please provide a proper ddl and dml. Help us help you, I doubt anyone will type all that data up from the picture to test things out in our local ms sql
SELECT TimeDate, Program, AGV, CAST(BattVoltage AS real) as ‘WiFi Reset’ FROM AGV.dbo.AGVfault
WHERE $__timeFilter(TimeDate) AND Program <> 0 AND Program in ($Program) AND AGV in ($AGV) AND Fault = ‘wifi reset’ and BattVoltage > 24.0
SELECT TimeDate, Program, AGV, CAST(BattVoltage AS real) as ‘Low Bat Reset’ FROM AGV.dbo.AGVfault
WHERE $__timeFilter(TimeDate) AND Program <> 0 AND Program in ($Program) AND AGV in ($AGV) AND Fault = ‘lowbattery reset’ and BattVoltage > 24.0
SELECT TimeDate, Program, AGV, CAST(BattVoltage AS real) as ‘Voltage’ FROM AGV.dbo.AGVfault
