I have a query regarding Grafana’s database behavior across different backends.
In the case of MySQL, Grafana inherits MySQL’s default case-insensitive behavior, meaning it treats datasource names like “prometheus” and “Prometheus” as the same value. Because of this, if a user already has a datasource named “prometheus” and then attempts to create another datasource named “Prometheus”, Grafana returns an error stating that “a datasource with the same name already exists.”
However, when using SQLite3, we’ve observed different behavior. SQLite3 treats “prometheus” and “Prometheus” as separate entries, and both datasource names are stored distinctly in the SQLite3 database.
Is this the expected behavior wrt MySQL? Why doesn’t Grafana treat “prometheus” and “Prometheus” as two distinct entries in the MySQL database? Does this behavior require a fix or any configuration change?
