I´m trying to create a query based on Postgresql creating a variable that should select all values from the chosen column (temperature, turbidity, dissolved O2, etc ). Is there somekind of example in that case?
Can you provide me with demo data and screenshots related to this?
you could create a dynamic query (not best option) or a view (best option)
view option
CREATE VIEW shabba_ranks AS
SELECT temperature as value, 'temperature' as metric
FROM table
union
select turbidity as value, 'turbidity' as metric
from table
union
select 'dissolved O2' as value, 'dissolved O2' as metric
from table
So this design assumes a few things, you have these in one table but we don’t know that since you didn’t provide the schema details of table(s)
Then in grafana you use
select value from shabba_ranks where metric = $column_variable
but this approach itself might not be the best approach but it depends on your table setup etc.
