i have parquet files stored in s3 in columnar format: like:
sample file:
s3://new-analytics-pipeline-stg/ad-minute_/year=2025/month=08/day=02/hour-01/minute=01/202508020101.parquet
i want to query athena connected to s3 via Grafana dashboard.
I have log files in parquet format in s3 written every minute to hive-style partitioned folders like:
sample file: s3:///stats-minute_/year=2025/month=08/day=02/hour-01/minute=01/202508020101.parquet
the stats-minute_table is partitioned by year, month, day, hour, minute
in Grafana panels, there is time range global column which has ranges like:
last 5 minutes
last 30 mninutes
last 1 hr
last 24 hr
7 days.. etc
eg: if i select last 24 hours, the Grafana query should automatically query only those year, month, day,hour and minute partitions which fall into last 24 hour range.
eventually i want table output with 2 columns as: 1>timestamp in yyyy-mm-dd hh:mm:ss format
2>Aggregated column (sum/max,min… etc),
assuming last 24 hours is selected in grafana global variable time range how should i write query such that i could to fetch data as fast as possible.
cuurently i am trying to write query like:
SELECT ts_gen,
max(sessions) AS “Max sessions”
FROM " acr_log_store".“stats-minute”
where
<date logic involving using grafana macros $__to and $__from>
