Im having the following timeout when a do a Query that makes a big search on the logs:
It makes the timeout always at 15s:
It is true that if a make the query with the labels, it does not timeout because labels are much more efficient on the query. But, I would like that, even the query is not made with labels, it would not timeout even it takes so long to make the query.
FYI: I increased ALL the timeouts of the config file already:
auth_enabled: false
server:
http_listen_port: 3100
grpc_server_max_recv_msg_size: 12667131 #<int> | default = 4194304
grpc_server_max_send_msg_size: 12667131 #<int> | default = 4194304
http_server_read_timeout: 10m
http_server_write_timeout: 10m
grpc_server_min_time_between_pings: 40s
querier:
query_timeout: 5m0s
tail_max_duration: 1h0m0s
engine:
timeout: 5m0s
max_look_back_period: 30s
distributor:
ring:
kvstore:
store: inmemory
etcd:
dial_timeout: 40s
consul:
http_client_timeout: 40s
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: inmemory
consul:
http_client_timeout: 180s
etcd:
dial_timeout: 180s
replication_factor: 1
final_sleep: 0s
chunk_idle_period: 1h # Any chunk not receiving new logs in this time will be flushed
max_chunk_age: 1h # All chunks will be flushed when they hit this age, default is 1h
chunk_target_size: 8572864 # Loki will attempt to build chunks up to 1.5MB, flushing first if chunk_idle_period or max_chunk_age is reached first
chunk_retain_period: 30s # Must be greater than index read cache TTL if using an index cache (Default index read cache TTL is 5m)
max_transfer_retries: 0 # Chunk transfers disabled
concurrent_flushes: 64
flush_op_timeout: 10m
wal:
dir: "/tmp/wal"
limits_config:
ingestion_rate_strategy: global
ingestion_rate_mb: 5
ingestion_burst_size_mb: 1
enforce_metric_name: false
max_global_streams_per_user: 5000
per_stream_rate_limit: 3MB
per_stream_rate_limit_burst: 15MB
max_query_length: 31d
cardinality_limit: 10000
max_cache_freshness_per_query: 10m
split_queries_by_interval: 30m
ruler_remote_write_url: ""
ruler_remote_write_timeout: 40s
ruler_remote_write_headers: {}
ruler_remote_write_queue_capacity: 0
ruler_remote_write_queue_min_shards: 0
ruler_remote_write_queue_max_shards: 0
ruler_remote_write_queue_max_samples_per_send: 0
ruler_remote_write_queue_batch_send_deadline: 40s
ruler_remote_write_queue_min_backoff: 0s
ruler_remote_write_queue_max_backoff: 0s
ruler_remote_write_queue_retry_on_ratelimit: false
retention_period: 35d
per_tenant_override_period: 40s
schema_config:
configs:
store: boltdb-shipper
object_store: s3
schema: v11
index:
prefix: index_
period: 24h
storage_config:
boltdb_shipper:
active_index_directory: /loki/boltdb-shipper-active
cache_location: /loki/boltdb-shipper-cache
cache_ttl: 24h # Can be increased for faster performance over longer query periods, uses more disk space
shared_store: s3
aws:
bucketnames: bucket-name
endpoint: s3.{AWS_REGION}.amazonaws.com
region: {AWS_REGION}
insecure: false
sse_encryption: false
http_config:
idle_conn_timeout: 90s
response_header_timeout: 0s
insecure_skip_verify: false
backoff_config:
max_period: 40s
s3forcepathstyle: true
compactor:
working_directory: /loki/boltdb-shipper-compactor
shared_store: s3
chunk_store_config:
max_look_back_period: 0s
table_manager:
retention_deletes_enabled: false
retention_period: 0s
ruler:
storage:
type: local
local:
directory: /etc/loki/rules
rule_path: /tmp/scratch
alertmanager_url: http://alert-manager.control.private:9093
ring:
kvstore:
store: inmemory
etcd:
dial_timeout: 180s
consul:
enable_api: true
enable_alertmanager_v2: true```
